- 18 May 2010
- London
The system you have your eye on, I think is good. However, by the time your going to spend £700 on a new Pc, I think you need to get something which will have some longevity to it.
The i3 is only a dual core cpu. Even though its clocked at 4ghz, I think an I5 or a Phenom Six core would be better price/performance.
The system below I think* is with your budget, with windows 7 and a 5770 it comes in at £730.
http://www.overclockers.co.uk/showproduct.php?prodid=fs-022-op&groupid=43&catid=1078&subcat=
have you googled to see if the 5770 is a good cardfor wow?
ok well according to this: http://forums.wow-europe.com/thread.html?topicId=11824286141&sid=1
The 5770 is good enogh for WOW but its all dependant on ram and cpu.
The system I linked to above has six cores at 3.6ghz which should handle WOW better than the i3 at 4ghz (which is only two cores)
Ideally I would advise an i5. But as your on a tight budget, and I think you need more than two cores, the Phenom II 6 I think should be good.
My understanding from a quite google is: i3 > Phenom6 > i5 > i7
http://www.techspot.com/review/269-amd-phenom2-x6-1090T-and-1055T/page8.html
