I never said they were amzing, but they are significantly better than 'Ok'. My point was that this is all purely subjective...and I, like the reviewer, rate them very highly in the dry.
are they ?
2nd bottom in dry laptime would say otherwise.
are they ?
Yes, obviously being "rainsport" tyres their excellent wet weather performance pulled up the average.
I still agree that given the poor dry laptime the comments gibbo made were valid.
depends which you think is most important - subjective oppinion or laptime.
If the latter you could be forgiven for saying they average in the dry.
It's really not that hard to understand, and I'm failing to see why you're unable to grasp this.
The Rainsport 2's, in this particular test, are rated as 2nd overall. Their Aquaplaning performance was second to none, but the rest of their wet performance, subjective or otherwise, was mediocre.
The OP clearly believes them to merely be 'Ok' in the dry. This going against the reviewer who marks them as very good, and thus second under dry performance.
The Rainsport 2's are significantly better than 'Ok' in dry prformance.
Another review of the Falken FK452 on the Focus ST, only problem is I'm a tyre noob and tried these after rave reviews on Focus STOC.
Falken FK452
Car - Focus ST
Tyre size - 225/40/18
Previous tyre - Continental Sport Contact 2
Dry Grip – Never got the tyres to squeel so maybe I’m not driving it hard enough
Dry braking – Acceptable, they do squirm slightly under very hard, late breaking
Wet Grip – acceptable, don’t really push it in the wet, wife manages to get traction control light to flash like mad when setting off mind.
Wet braking – OK I guess but see above about not pushing in wet.
Sidewall – No idea how stiff it is
Turn in – It works but can feel a floaty at times
Feedback – As MrMoonX said you can really hear the road surface change and all the lumps and bumps through the wheel
Comfort – Quite a lot of road noise, not much give over bump either
Summary – For the money they are, for me, as good as the Continental Sport Contact 2 the Focus ST came with. I would like something with better wet performance next though. Also the fronts have developed a really annoying deformation that caused a lot of vibration. Wear rate is quite good as they have 4mm left on the front atfter 9000 miles of dual carridgway & motorway driving.
Can we just make something clear.
I am not reviewing the tyres, the idea was to collate mainly information in regards to sidewall stiffness of different tyres.
The in brackets where I've put OK dry, great wet comes from reviews I've read and other user comments. The reviews is further down and I've submitted two reviews of tyres on same car comparing against the previous tyres it had on.
I am sticking by that Rainsports are OK in the dry and very good in the wet. There are far many superior dry weather tyres out there which when compared against such tyres make these OK, is that so hard for you to grasp?
For me a tyre is either terrible, poor, ok, excellent/great or amazing/sublime.
So for me the Rainsport from reviews I've read, peoples comments I would come to the conclusion dry grip is OK, there are loads of tyres out there with better dry grip, Goodyear F1, Conti CS3, Conti P5, Michelin PS2, Advan AD08, Toyo R888 and more. So when in such company how on earth can the Rainsport be any more than OK, all of those tyres are superior in the dry.
My point, all along, was do I beleive a random, who doesn't review tyres for a living, and doesn't work in the motorsport industry that the Rainsport 2's are 'Ok' in the dry. Or am I in fact more likely to beleive a professional reviewer with years of experience in the industry to tell me that the Rainsport 2's, are better than Ok.
It seems blindingly obvious to me that anyone who had driven the Rainsport 2's over 1,000 miles across different surfaces, and in varying conditions would tell you that the Rainsport 2's are better than 'Ok' in the dry.
Nope the problem is just as Fox has said it depends on a persons expectations.
If I fit Rainsports to my car for example for me I would find turn in terrible, roadfeel poor to OK, dry grip OK and wet grip very good.
Because I've driven cars with R888, Advan AD08's, Michelin PS2's, Vredsteins, T1R's, Pirellis, Goodyear F1's etc. and when compared to those the Rainsports are just OK in dry grip because those tyres give a lot more dry grip, thats a fact.
For instance, the Vredstein Ultrac Sessenta is an OK/Good dry grip tyre, but for me I'd say its just above OK because in dry grip the Advan AD08 is vastly superior.
So on my scale of things and to my expectations the Rainsport will never be anything better than OK in dry grip for me.
Have you driven a car with R888's, Advans or high spec Summer tyre like Conti 5P or Michelin PS2?
I can guarantee you if you fitted a set of any of the above your dry grip would improve and it would improve massively with something like an R888, and then you'd too be thinking well when compared to a tyre like the R888 then yes I suppose the dry grip is just OK.
OK is not a bad thing, but there are far stickier dry grip tyres out there.
But as far as I am concerned the Rainsport 2 performs OK in the dry, its not excellent and its certainly nowhere near sublime.
Sounds to me like you've flat spotted the fronts, which normally comes from breaking very hard and locking up. If you want better wet performance, look at the Conti CS3's.
I hadn't considered it had been something of my own doing.a) Significantly more expensive (than the Rainsport 2's)
b) Wear more quickly due to compound (T1R's & Eagle F1's)
c) More suited to the track, than the roads in the Uk.
The issue here is a random reading the thread would think: 'Ahh, the Rainsport 2's are only 'Ok' in the dry. I'll go get some T1R's instead.' Said random would then overcook a corner in the rain, lose control, and total car / possibly hurt themselves in the process. This is why perpective is needed. You cannot simply say 'x is just 'Ok' in the dry' and leave it at that. This is why you should leave tyre reviews to the Pro's - they have a proper perspective, we don't.
My view is that, so far in my experience with the Rainsport 2's, the dry grip is good, the wet grip is good, and all in all they are very confidence inspiring. I have no doubts there are better tyres for the dry, and better tyres for the wet, but as a package for your 'normal' consumer, there are few tyres which do so well when considering all factors.
