- 17 Jun 2005
- Near Brighton
I'm in need of a new headset.
The past 2 headsets I've had have been Speedlink Medusa 5.1 sets (both 3.5mm with amps). I actually thought these were pretty good (sound wise) but they both ended up breaking / snapping where the earphone attaches to the headband. I'm not sure if i want another set but I'll probably try something else.
I used to always use my headset, due to playing wow a lot and being on ventrilo most of the time. I don't play wow anymore, so using my Z-5500s a lot more. These days it will be used at night or when i need to use a mic, so needs to be fairly decent with black ops coming up, will be playing a lot with friends.
Which headset should I get?
I don't have a specific budget, tho definatly under £100 but closer to £50 probably. Brand wise, Logitech stuff has always been fantastic for me but what else is out that.
Also, Stereo vs 5.1
I liked the 5.1 (or 'virtual' 5.1) from my speedlinks. are stereo headsets that much better? is the directional part of the 5.1s utter crap?
Thanks
Also, Stereo vs 5.1
Thanks
