NASA UFO Footage
Sapce is not earth, and when do you see tiny particles on earth hitting each other on earth with zero mavity and zero resistance.
That's the problem with most Space CT, you try applying earth logic to space.
When in fact all you need is the most basic mechanic maths, which have no resistance in the equations.
I am basing my thoughts on the conditions its under, in fact thats what makes this so hard to explain away so easily, objects react almost instantly to being hit with an equal and opposite reaction, these speed and direction changes are so gradual and smooth that random hits don't work, the physics is wrong if thats your answer, yet you never explain how and why it happens, instead you ignore the point of the argument and instead find some little bit you can use to divert away from the point while thinking you're somehow progressing and 'winning' the argument, its a bit of a joke, explain how and why there are invisible particles all hitting from one direction and ill listen, until then your 'explanation' is as bad as most conspiracy theorys i've heard.
some of the direction changes and velocity changes of some of those objects are certainly very "weird" for just a bit of debris/ice.
also the comms from the high trained shuttle astronauts are very interesting. you would imagine they would be able to tell the difference, unless they are suffering from some kind of space sickness that is causing them to hallucinate?
If Astronaughts were hallucinating in space with $billions worth of equipment and vehicles then there are far more important questions to ask which are more local than extraterrestrial.
UFO =/= alien
I have to laugh at these 'open minded' people. Its as though they want to see aliens in every bit of blurry, badly shot, shakey bit of cam footage of something that is an Unidentified Flying Object.
Note, UFO doesnt contain the word Alien. Never has, never will.
And, if the object was identified as an alien, it wouldnt be a UFO. It would be identified. So an FO.
And when they land, they will be an O.
I am basing my thoughts on the conditions its under, in fact thats what makes this so hard to explain away so easily, objects react almost instantly to being hit with an equal and opposite reaction, these speed and direction changes are so gradual and smooth that random hits don't work, the physics is wrong if thats your answer, yet you never explain how and why it happens, you're as bad as magick with your explanations.
I have explained, you have lots of debris up near the ship. Be it ice to dust from launch rockets. You also have various streams from difference directions, be it directional thrusters to other particles bouncing of the hole.
There is in fact lots of stuff moving in a similar direction and a lot of stuff moving in random ddir4ctions, with a huge variance in size, mass and speed.
Combine that with the camera effects, that show these objects are extremely close and out of focus. Unless you believe these polo like objects can pass straight through the tether with no damage to either.
i hear theres an alien base on the dark side of the moon and thats why we have never revisited because they made threats against the earth :D
I don't believe that, it's almost certainly Space Nazis on the dark side of the moon.
On Topic, that video is nothing, just glithes, artifacts, dust etc... If aliens exist, which in all probability is high, why would they visit us? We have literally nothing useful for beings capable of extended space travel, especially not useful enough to actually hide and study us. All humans are as a species are animals that can't stop killing each other, the aliens might aswell be watching the lions & tigers.
Also, basically calling people who don't believe that a terrible quality video of dust and glitches 'ignorant' because they don't believe it's aliens, get a grip.
We're only useful for observation in the same way we observe our earth animals, insects, bacteria etc to see how they evolve, interact and go about their daily business.
That's the way of life y0.
I liked the footage of the Astronaut looking at a flying saucer on his pc screen but I guess that it could have been photoshopped in.
You're not taking into account the physics of collisions, chance, how big space is and you presume a lot about how big these things are, how close they are, why and how there are so many invisible objects and why the same effects aren't felt by other objects close by, there's a lot going on, take another look at the tether video, jets do not account for one or two random objects changing speed and direction the way they do without effecting others and the idea of multiple collisions from invisible objects is too unrealistic to be worth considering, its as bad as believing they're aliens.
Good video but i suspect that most of the stuff floating about is just debris and the things changing direction could be anything from Satellites changing direction to stuff bouncing off the earths atmosphere?
Satellites don't changed direction at any perceivable speed... Things don't bounce off the atmosphere unless going very fast...
I am, as well as camera problems. which is why these objects looks see through and appear to pass through other objects.
Objects are only visible if there is a light source on them and tehy are big enough/moving slowly enough for the camera to pic up. The mere fatc it is space and particles in "close" proximity is exactly why we see such movements.
one of the astronauts says something like "this object is tagging along" thats some very clever "dust/ice/particle"
Im sticking to motion for now, im going to leave any arguments about distance and size out of it as you can't be sure in space, nothing passes through another object, it might look like it due to low quality video though.
Watch this video or skip to 1:40 if you must, can you honestly tell me you think particle collisions cause that?
yes, just because they've added flight paths in. it is still totally possible for such movements.
Your right you can't tell distance or size in space. However the camera problems are common when you zoom up to a small object close by. this affect is common, appears to make objects see through and also arises to the fact it looks like objects can pass through each other. they are camera glitches.
So we can say almost certainly the objects with the glitches are close by and small. It is therefore likely the rest are also the same.
