Caporegime
- 21 Jun 2006
The 3 you listed are pumps. State GT isn't a pump product itself. It's a pre-workout supplement tho yes, but I use it simply for it's great effect of giving me lots of energy endurance etc.
If it helps bud im a company rep for LG Sciences.
thanks for all your help, i have done a lot of reading and it seems as though state gt is the best product to use, but it doesn't seem to be very popular in America. therefore im going to use just 1 at a time, so i can see the difference between the 2 personally.
im not doubting state gt, i think its an amazing product, im just going to compare the 2, so i know for sure, next time when i order again, which one to go for.
so next time i will probably order 6 bottles of state gt instead of 3 (and 3 jacked) depending on how i feel about them after the comparison.
i dont doubt what your saying, its just that if i take both products at the same time, i wont know which one is working or which one is giving me better results. this way i will know for sure.
thanks for your help.
if you get some free samples, be sure to send some my way, im not like those guys who just want free samples for the sake of taking them, i will buy the product if i like it and it makes a difference, as you can see by my bulk order a couple of weeks ago.
