- 20 Jul 2009
- Midlands
Pre order the worlds largest internal hard drive. Western Digitals WD30EZRSDTL 3TB Cavier Green is the ultimate in single drive storage prividing performance on par with the markets leading drives. Dont hesitate, BUY NOW!
Western Digital 3TB Caviar Green SATA 3Gbps 64MB Cache @ £191.98 inc VAT
Massive capacity - WD Caviar Green SATA drives now deliver up to a massive 3 TB's of storage on a single drive.
WD meets the technological challenges of implementing 3 TB SATA hard drives - SATA hard drives are now capable of storing up to 3 TB of data on a single hard drive. WD is leading the way in the industry, providing you with solutions for implementing 2.19 TB and larger drives.
Reduced power consumption - WD has reduced power consumption making it possible for our energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation.
Cool and quiet - Drives with WD GreenPower Technology yield lower operating temperatures for increased reliability and low acoustics for ultra-quiet PCs and external drives.
Perfect for external drives - External drive manufacturers can eliminate the need for a fan in a high-capacity product by utilizing the cool and quiet operation of WD Caviar Green hard drives.
IntelliPower - A fine-tuned balance of spin speed, transfer rate and caching algorithms designed to deliver both significant power savings and solid performance. Additionally, WD Caviar Green drives consume less current during startup allowing lower peak loads on systems as they are booted.
IntelliSeek - Calculates optimum seek speeds to lower power consumption, noise and vibration.
NoTouch ramp load technology - The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
Advanced Format (AF) - Technology being adopted by WD and other drive manufacturers as one of multiple ways to continue growing hard drive capacities. AF is a more efficient media format that enables increased areal densities. (RS and RSDTL models only)
Manufacturer: Western Digital
Cache: 64MB
Capacity: 3000 GB
Access Time: 8 ms
Edition: Caviar Green
Interface: SATA 3Gb/s
Form Factor: 3.5"
Free-Fall Sensor: No
Height: 26.1 mm
NCQ: No
Rotation Speed: 5400 rpm
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Only £191.98 inc VAT.
ORDER NOW
Cache: 64MB
Capacity: 3000 GB
Access Time: 8 ms
Form Factor: 3.5"
Height: 26.1 mm
NCQ: No
ORDER NOW
I've not really read into it I just figured it would be pretty ace to use in one.
