- 12 Aug 2005
- Orpington.
As above, with all these upcoming new cards what will trounce my set-up?
wouldnt you be better of just dropping the 5870 and using just the 5970 as tri-crossfire is crap?
Actually tri is probably the sweet spot when it comes to multiple card performance. Quadfire doesn't scale as well as tri from what ive read.
What are you using all that GPU power on or do you just bench?
what you gotta ask yourself chief, is £750+ on 2 cards worth it ?
been thinking of sli myself, but the cons far out way the pro's
