Caporegime
- 13 May 2003
- Warwickshire
Anyone know of a way to wake the screen without having to press the power button? I.e., press to wake screen then swipe to unlock?
i bought the genuine htc pouch, HTC Desire HD ACE Pouch PO S550.
has a nice pull tab so you don't leave the sim cover in when you pull it.
[/IMG]
On the lookout for a mount in the car, something to use when using the sat nav on the HD.
this one look's different from the usual cheapy ones..
http://cgi.ebay.co.uk/Clingo-in-Car...UK_Mobiles_Accessories_RL&hash=item20b3e2f013
Anyone know if its any good?
Is anyone having issues with seriously slow web browsing over your data network ? using the device in a GPRS only area is stupidly slow, compared to my iphone 3gs (same network) it loads the page much much quicker?
I was sat there waiting for 25-30 seconds to load ocuk forums where as the same test on iphone 3gs took around 5 seconds
Why is there no easy global solution to silent the DHD? I did silent, so calls are quiet, then suddenly apps aren't silent!
Why can't there be one button that mutes the lot? Not very easy for work...
A fix has been found to stop the /Init process lagging the phone.
On your phone go to..
Menu/settings/applications/development/now turn on Usb debugging..
This seems to keep the / init process at 0% CPU usage, it also works when the /INIT problem starts, turning USB debugging on will make the /INIT process drop back to 0%, very nice to see.
Ive contacted the Dev to find out if he can tell us why this method has fixed the problem.
Still need an update from Htc but at least we can use our phones again..
There doesn't seem to be any negative effects from turning this option on, the only thing to note is turning it off to connect to your pc could bring the /init process back and lag your phone. You can download Android Manager from the market for free which will allow you to transfer data from your pc using Wi-Fi, using this app you can keep the USB Debugging on.
EDIT 2 - It looks like you can connect to the pc via USB cable with the debugging turned on without problems, the only difference is that it will try and install additional drivers...because of the debugging mode..
Im using windows 7 and the ABD driver wont install...this however does not effect transferring via the USB cable...
We should also watch the battery as this may actually increase battery life...
Thank you to everyone in this thread for there efforts...amazing response.
How are some of the earlier adopters finding it after spending some time with the handset?
Liking it?
For the first time I think I'd be happy to carry this phone on after my contract ends.
Thats easy to say, near impossible to do though![]()
Oh, I'm not saying I will - there'll be a 1g lighter and 1mm thinner version out by then.
