Done them all mate not really changed a lot tho to be honest these are the reading i get now.
3517 kbps 991 kbps
Line Attenuation 64.5 db 35.5 db
Noise Margin 10.00 db 0.5 db
Not really much else i can do i guess. I remember when i was with talk talk they would change the line profile to a lower DB dont know if virgin do anything like that but i doubt it hey
Been with be for 2 years and it's awsomebell wire mod I done 6 months ago boosted me from 13.5mb download to 18.5mb Down 1.4 up
Love it![]()
I'm contemplating bonding
Bell wire mod? Do tell us more
Nevermind just found this - http://yarwell.blogspot.com/2005/08/adsl-tweaking.html
By far the best tweak I have made on my connection to gain some extra speed.Thats the tweakBy far the best tweak I have made on my connection to gain some extra speed.
I'm 3.2km (I think can't check DSL zone atm) and I get 10meg down 1.2meg up... Will try this when I get in .... Worth a punt
I just disconected my ring wires from my outside bt box as thats where my box is, disconected all the ring wires from my 5 sockets in my house, and these are my results
before
Connection Speed 3409 kbps 1023 kbps
Noise Margin 10.40 db 1.5 db
after
Connection Speed 3625 kbps 1023 kbps
Line Attenuation 64.0 db 35.5 db
Noise Margin 10.00 db 1.5 db
Im 80% sure you will see an improvement. The big question would be how much it will improve.
Might be easier to project with some current line stats
Not really a huge increase
Given that I had +5mb when I done it. Are you sure you completely removed the wire? are you connected to the master socket?
EDIT: Just seen your downstream attenuation, either you have some dodgy wiring or your really far from the exchange hence why you didnt really see much difference.
i cant connect to my master socket as its one of those ones in a grey bt box outside. I can see my line can support 3-4mb and my downstream atthe mo is 3.6 so i guess its kinda not to bad
