mikeh said:so you can probably still get this sorting for nothing
[TW]Fox said:iirc
[TW]Fox;17759020 said:The key difference between a recall and a tsb from the ops perspective is that Ford won't fix it for free out of warranty if It's a tsb but they will if It's a recall, iirc.
Sounds like you're about as sure as I claimed to be, so why are you jumping on a technicality in terminology?
FWIW, Ford customer care will often authorise stuff like this outside of warranty according to my local dealer.
snip
For the Lolz I looked up the 0-60mph
Evo X 4.5s
M3 E90 4.5s
Scooby WRX 5.7s
Focus ST 6.6s
Corsa VXR 6.8s
MW
Get a Focus RS, they look better and are cool.![]()
I suspect he means a mk1![]()
Just make sure you keep some back for Dreamscience![]()
The car is pre facelift but with red stereo/gauge lighting, I thought it was green up until facelift,
Late 2007 will have the intermediate facelift revisions, things like the newer, prettier stereo, red SMD lighting rather than green etc. etc.
id save up for mountune.... much better.
Oh, go on then, I'll take that extra £11k from you!![]()
You know full well what i meant.Im not wrong though am i?
