Which current card, or wait?
18 Oct 2002
Milton Keynes
Yo all
Currently have an 8800 and black ops is basically unplayable even on low (although at 1080) so looking to buy a new rig
Not sure what to go for, be it AMD or Nvidia, have always been a big fan of nvidia, their larger price tags dont bother me
What should I go for? Or is it worth waiting for something out soonish?
Ta in advance
Have you checked framerate? a lot of people are finding the game feels like <30fps much of the time even when kicking out good framerates.
Depends on what you plan to spend, if your looking at £200+ cards then I would wait for the new ATI cards.
I'd figured around £400? Wanted the new rig to be good for when BF3 comes out so I want to get as good as poss
framerate is pretty spikey, however a mate of mine on virtually the same spec at least finds the game playable. think the game needs a good old patch and it will be playable on low settings
Defiantly wait then. £400~ will probably be enough get you the top end HD6990.
What was this in aid of? pretty random? :p
Defiantly wait then. £400~ will probably be enough get you the the top end HD6990.
Defiantly or definitely?
I can't see the 6990's being less than £400, the 6970's maybe.
However as the op obviously has a liking for Nvidia cards then the GTX 580 would seem to fit the bill perfectly, and these can be had for around 400 quid right now :)
I would not spend money upgrading just for Black Ops atm... I'm on a fairly decent spec and getting 100+fps in the game and it still only just about feels playable - if I didn't have the framerate counter up I'd swear I was sub 30fps quite a lot of the time.
I will go with the 6990 if its going to be better than the 580, just have been out of the game for a while so dont know whats best anymore. Clock speeds on the AMD seem higher but then some people still think the Nvidia are the better cards
definitely dont mind spending a bit more for quality / less chance of it bricking in 2 years / lower temps etc
not JUST for black ops. as above I want this PC to own for battlefield 3 as well, plus the mrs needs an upgrade so she will get my current rig, and been wanting a new machine for a while now :P
I'll be suprised if the 6970 is under £400 - unless it can't match the GTX580 - based on rumoured specs it should comfortably match it atleast.
It looks like ATI have gone with small core ( least expensive small core option ) 2000~ sp core for the 6970 and the 1600~ for the 6850. That would make them about 1.5 - 1.6x ~ faster than the year old cards they are replacing and more than likely cheaper to build. As long as TSMC have hit the ATI the production targets ( looking at the £399 RRP GTX580 TSMC have improved a lot) they should be very reasonably priced.
£400 and £500+ with 7000 cards due shortly they would have to offer a 3DFX type performance jump on this and the next round GPU's, and I can't see that happening with ATI's efficiency first, bang for buck strategy. I kind of hope ATI have gone with the massive super fast expensive core, as I can see a gap for something that really offers uber high end performance, but I think its unlikely that ATI will have moved form the small core plan, especially with the electronics industry in its current state.
I know that the CoD Engine hasn't changed that much from MW to WaW to MW2. I do know that CoD4 and MW2 ran great on my old 8800GT and I had no problems at all at 1680x1050 with all the in game optiosn on with both games. not sure why you'd have problems even though you are running 1080. I can't imagine it would be that different.
want a whole new rig, just the gfx card is the only bit i am unsure of really
and yeah mw2 runs absolutely fine for me mid details @ 1080, but i swear black ops is literally unplayable. i see someone, goto shoot, freeze up, then i'm dead :(
I definitely think its issues with the game rather than my spec, but until they bring out a patch that may or may not solve my problems I am looking into this avenue of resolution :P
