- 23 Dec 2009
- RG8 9
50% plus 10% off the 50% on EA Store
***EDIT 27/11/2010***
UNFORTUNATELY THIS DEAL IS NO LONGER WORKING.
Thanks to gizmoy2k for giving me the heads up in the MoH thread.
As far as I can see, this is working for pretty much EVERY game, apart from stuff already in a sale, or special editions and pre-orders. *EDIT - WORKS ON CRYSIS 2*
You need to allow pop-ups on the EA Store to get the extra 10%.
Go to - http://eastore.ea.com
Select a game, choose digital download, put it in the basket. Where it says: If you have a promotional code, enter it here, type in NextJump.
You should now have 40% off.
To get the extra 10% off the 40% you have already received as posted above, you need to have pop-ups enabled. Click the EA logo at the top (to take you back to the homepage) and a pop-up should appear which states something along the lines of "boo hoo, you were at checkout and you did not buy. Click one of these things to tell us why, and you can have another 10%".
Click that, then ALL avaliable games will be showing with the 40% off price (if they have one) and when you go to checkout the extra 10% will also be applied.
So for instance, Medal of Honor was £29.99. It is now £16.19.
*EDIT*
USE CODE i41 INSTEAD TO GET A WHOPPING 50% off. 10% fix also still works!
MoH £13.49
BC2 £11.49
Plus other games.
*EDIT*
MoH £13.49
BC2 £11.49
Plus other games.
