- 27 Aug 2003
- West Midlands
That looks perfect
I looked at getting rubber tiles as you see in a lot of the american style "show us your garage" threads a couple of years back, but they were very expensive.
Depends on how harsh the usage is going to be, most vinyl's wont wear well enough i wouldnt imagine. The best option for a cheap fix is a floor paint as they use in a lot of commercial garages.
Edit: that ebay link seems very cheap, at that price just buy a batch and see what they are like imho.
I've just done mine with the ronseal sealer and paint.
The concrete was so dusty I did 2 coats of sealer and 2 coats of paint. The finish is good.
I would also suggest washing the floor first with some kind of detergent based cleaner, otherwise in any patches where oil has been spilt you may also get the paint and sealer peeling.
Don't expect much change from £150 to do a double garage though :O
Mustard
