Decent server mate I've been on there quite a lot today. What's your in game name?
Just played in the FAP server, one of the better ones ive played on.
[LTUK] 1 [RANKED] BlackOps
Right, I've gotten around to checking this out after being a COD fan for some time now, and Treyarch have truly forgotten how to make a PC game.
Let me explain:
THEY HARDCODED THE CONFIG FILES TO USE 1GB RAM!
Did that grab you enough?
Now, to fix it.
Go to your install directory, and open config.cfg in a text editor, such as Notepad.
Change the following values:
seta sys_sysMB "1024" -> To where 1024 is the number of MB RAM you have (likely to be 4096)
While you're on, change:
seta r_multithreaded_device "0" -> Change the 0 to a 1 unless you have a single core CPU (highly unlikely)
Also, change the value:
seta r_multiGpu "1" -> Change the 1 to a 0 unless you're running SLi or Crossfire.
With that, the game becomes playable.
Did Treyarch even bother to check the default config files before they released this?
I would put my opinions on this matter into words, except the only character used would be *. Muppets.
[FAP]Naffa[FAP]Benjo![]()
I can't find config.cfg
EDIT: Found it. It's config_mp.cfg
i think the game wants a quad at least for constant smoothness and nothing less.
Right*. Muppets.
Anyone know which member on here runs the TFU server so I can contact them.
I have been banned from their BC2 and MoH servers, not even going to bother trying to play on their Black Ops one.
I tried the TFU server and tbh its one of the worst performance wise ive played, and i have no idea why but it was so laggy for me.
is it anything to do with me having OcUK tag?
Guarantee if they're on here the excuse will be "LOL SOZ MAN, HAD TO MAKE SPACE FOR A CLAN MEMBER"
Sounds like a friendly server, kill us and get "teh banzor" for "insert concocted reason here".![]()
As far as I am aware only 2 people have been banned from our server and I banned them both. I know for definite that you were not one of the ones I banned.I don't mind getting kicked for letting their own members on their own servers, but banning me, hmmm.
So I downloaded cfg files that this guy created from using MW2 game and now my game runs 100 better than before with any resolution, previously it was dead slow even with everything set to low and lowest resolution possible. SP was even worse than MP. And now everything seems to be almost fine. I am not sure now if the servers still lag as I still get some lag even though my fps stay high.
Source
