Ok so say your up against a party which fills half the lobby and they rape you, their going to want to pick that map again and again and again and again because its easy kills and an easy win all the time. Not exactly ideal is it
On another note just started the single player mode and omg what a ****take, think its the 3rd mission im on where you have to destroy the rocket. im on to the bit where you have to go kill that man and im inside a tunnel and the enemys just keep coming back over and over again. they seem to be never ending, im starting to get so bored of sitting in the same place just shooting them coming round the corner and up the tunnel and i cant move because when i do i die and have to start all over again
You need to advance else they'll just respawn FOR EVER!![]()
Which bit are you stuck on? Ive only got stuck on the barrel bit on vietnam cause i didnt realise you had to knife them
I cant because everytime i do i get shot and die so have to do it again. Went through 5 different guns
Be more careful? I know the bit you're on, I've done it on veteran - try and push into the left alcove then the room across on the right then from there to the end of the corridor for a checkpoint.
When you get into the left alcove your guys should hopefully push up a bit.
Aw right i'll give that a go then when i go back on it. Cheers
If you're an a party and it's taken you 5 minutes to find a game it's annoying having to leave a lobby because people keep choosing the same map over and overJust leave? Surely that's the easy option?
Anyone else finding party match making to be a pain? seems to randomly disband the party when searching
You have to knife the barrels? Thank you! Thank you!
Are you winning thats all that counts. Some games I'm positive, sometimes I'm 20 for 4 like you because I'm throwing myself at objectives even if it's just to distract at A while eveyone captures at B.
As long as I win I don't care anymore with this one. Back to the way I used to play Cod4 and I love it.
Got mine from Sainsburys for £25 with £30 worth of shopping.Tesco or Asda have any deals on at the moment?
