Call of Duty: Black Ops
Ok so say your up against a party which fills half the lobby and they rape you, their going to want to pick that map again and again and again and again because its easy kills and an easy win all the time. Not exactly ideal is it
On another note just started the single player mode and omg what a ****take, think its the 3rd mission im on where you have to destroy the rocket. im on to the bit where you have to go kill that man and im inside a tunnel and the enemys just keep coming back over and over again. they seem to be never ending, im starting to get so bored of sitting in the same place just shooting them coming round the corner and up the tunnel and i cant move because when i do i die and have to start all over again
You need to advance else they'll just respawn FOR EVER! :eek:
Which bit are you stuck on? Ive only got stuck on the barrel bit on vietnam cause i didnt realise you had to knife them
I cant because everytime i do i get shot and die so have to do it again. Went through 5 different guns
Be more careful? I know the bit you're on, I've done it on veteran - try and push into the left alcove then the room across on the right then from there to the end of the corridor for a checkpoint.
When you get into the left alcove your guys should hopefully push up a bit.
Leave and find another lobby? Really don't see the problem personally.
Aw right i'll give that a go then when i go back on it. Cheers
Also try laying down some smoke to get into the corridor itself plus you dont need to get to the end of the corridor to hit the checkpoint, I got it in the room on the left but bear in mind to clear the room on the right first and smoke the corridor as you cross as there'll still be Russians to your right and in the room you're heading to!
I know which bit you mean as well, throw a smoke down the corridor in front of you before moving into the room on the right. From there, there are 2 areas you can crouch, try and head for the far right hand side and pick the 3/4 guys inside that room off from range. Then, move forward and the AI team should move up the corridor and stop the respawns. You should then also get a checkpoint.
This bit was a major PITA.
Are you winning thats all that counts. Some games I'm positive, sometimes I'm 20 for 4 like you because I'm throwing myself at objectives even if it's just to distract at A while eveyone captures at B.
As long as I win I don't care anymore with this one. Back to the way I used to play Cod4 and I love it.
If you had lady parts i'd put my man parts into them... i love you Danny! :D
Favourite perk so far?
Mine has gotta be hacker pro. Hack a claymore,run off and watch it kill the planter. Hack a SAM turret and watch it shoot down their gunship. I've yet to booby trap a drop crate.
