. You should check for it using the settings that you are comfortable using - so 10% brightness in your case. If you do manage to receive a good unit (like PCM2 or bigjimmyauk have), then it seems like a very good monitor. Just be wary that it appears there's more dissatisfied owners who are returning the monitor due to a few defects.Right, I have a Mac Mini on the way via the refurb store. Bye bye laptop! Is this the best I can get for around/under £200? I'm essentially looking for a bargain that'll be for most things except gaming, since I plan on having a separate monitor (and computer) for that.
It normally is, which is why previously I always looked at it and thought "that'd be nice to have, shame about the price" and carried on looking at cheaper alternatives. I couldn't really let it go at it's current limited time price.Ah bugger, I thought it was still in the £260 range which was too much. Now I'm feeling indecisive!
Yeah those are my worries, but I think for me at least, it's worth the gamble.I'm not sure what specific rights I lose out on ordering the Dell as a 'small business' though, and you mentioned were hoping you'd get a panel without tinting or backlight issues, so an equal risk applies.
I've not heard them myself in person (although you can somewhat listen to them in NCX's review), but I'm guessing the speakers are going to be pretty bad compared to an external set. Usable I guess, but being only 1.5w, they're no better than your standard laptop speakers. If you don't have any alternatives then I suppose you've got no other choice but to use them.Don't laugh but the BenQ has built in speakers, and it's going to be a while before I can get myself the DAC and active monitors that I want, so I need some kind of speakers in the mean time. One the down side the warranty is 2 years to Dell's 3.
Datalol-jack mentioned he was ordering a large batch of BL2400PT (same panel as the EW2420). You could probably gauge how likely you are you receive a bad unit depending on what he receives. From what I've personally read across a lot of forums, sites and in different countries/languages, there have unfortunately been a high number of bad apples, so to speak.I'm swaying towards the BenQ and ordering from the same place PCM did, in some sort of vague hope they have a 'good batch'.
