Gigabyte 460GTX and COD black ops
even sitting in the menu screen or the press any key title screen has 100% cpu load :|
just doesnt seem right lol.
It's not struggling, it pretty much stays at the 90 FPS cap, I'm just confused how they could turn what is basically a MW2 clone in to a resource hog, the low GPU usage is causing the odd stutter and lag in single player as well, MW2 played like a dream.
You do know you can remove the cap don't you?
It is important to note that by default Call of Duty: Black Ops is frame rate limited to 85fps. However, this is very easy to modify either in game using the console command "com_maxfps," or in the user configuration file before entering the game
This is why I consider COD by Infinity Ward and COD by Treyarch are different game series under the same name....:mad:
Then again Infinity Ward is pretty much dead with the core members and majority of the employees left, so I guess should look forward the new titles by Respawn Entertainment instead.
