Zalman VF3000F-GTX480 GPU Cooler Review!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
You may remember a few months back when Zalman released the VF3000 coolers for ATI 5800 Series GPUs and the GTX 280. Well I have a nice new shiny toy that I have played with tonight.
I have tested the new VF3000F cooler for GTX 480 cards :) As most of you know the GTX 480s run very loud and quite warm, the cards are designed to be perfectly stable at those temps, however the noise does annoy some.
Anyway, lets get on with it.
Installation
This was easier than the older VF3000 ATI 5800 and GTX 280 cards, the main reason is the VRM and RAM chips on the card had a seperate cooling block for each chip - which was secured by the heat pad alone (which didn't feel 100% secure). However with the GTX 480 cooler from Zalman you have 1 single large heatsink shaped to fit over all the chips, they are also secured by spring-screws and you even are given small rubber rings to protect the GPU circuit board when screwing the heatsink on.
I did find the Zalman STG2 paste very thick and it doesn't apply easily, it's thick consistancy meant that applying the paste to the small chips would result in the chance of a small bit of paste going onto the PCB. I would recommend a steady hand and something to dab the paste off the end of the syring to ensure no excess paste gets onto the PCB - the paste isn't conductive so not a major issue if it does anyway (clean it off if you can though)
Other than that the cooler was easy to fit.
Performance!
Here is a screenie of the stock cooler running furmark - I left the cooler fan speed as standard and left the card to speed up the fan.
Stock Cooler Results
GPU Temp - 92
PCB Temp - 72
RAM Temp - 86.8
Fan Speed - 74%
I run the same test with the Zalman cooler fitted and set the fan speed to max (45%) using the Fan Mate controller (included). The fan noise was no louder than the stock case fans in my Corsair 800D.
Zalman Cooler Results
GPU Temp - 73
PCB Temp - 55
RAM Temp - 67
Fan Speed - 46%
Other comments.
The only thing that did let me down was the LED's on the fans, I thought great, a green LED to light my case up a little, giving a nice ambient glow. However the LED lights were that dim that they were hardly visable. The cooler also takes up space over the next expansion slot, so running SLI will be tricky :(
Conclusion!
Overall for anybody running a single GTX 480 GPU this is a great purchase, as it gives amazing cooling performance and is hardly audible. A stock GTX 480 is majorily let down by the noise it generates so for anyone looking for a quiet system this is your choice!
Stock will be arriving on Thursday :)
Zalman VF3000-F Graphics Card Cooler (Nvidia GTX 480)
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
Only £34.99 inc VAT.
ORDER NOW
Yet another excellent mini review! Very similar to the cooling solution fitted to the Zotac AMP gtx480 that costs a good £50+ more than a generic unit so with that in mind this looks to be a bargain! Nice to see cool temps in a slightly restrictive case in terms of internal airflow.
Andy
Hmmm, think I'll have to get me one of those purely off the back of this review - anything to give me some headroom before hitting the water :)
BTW what case were you running this badboy in?
Cool - mines being fitted into my freshly unwrapped (care of OcUK) 800D this weekend :)
Good choice of case and cooler :) And GPU, you will enjoy it, I know I do.
It wasn't the most comfortable parcel to transport 6 miles through London though lol. I'm saving the work for the weekend, partly due to the hassle of draining my water loop and partly because I'm at Uni over the next couple of days and I really don't want to be fire fighting any potential issues while attempting to complete college work!
Hopefully stock comes in early on Thursday so I can grab my order before the weekend.
Correct, so SLI isn't possible on a dual PCI-E motherboard.
The Zalman cooler is much lighter than the stock cooler too.
Though it has to be noted - you prolly still won't be able to carry your 800D very far lol. Its pretty handy knowing the weight thing I for one tend to get a little paranoid of heavy coolers.
the gelid is a great alternative.
plus it would be quite rude to not consider a gelid
or even gettagelid :)
