I have both.
Here's what I prefer on the XBOX... The controller
Here's what I prefer on the PS3.... Just about everything else.
LOL, you should get one of those Cross Battle whatsits so you can use the 360 controller on the PS3.
I have both.
You will either:
a) Buy a PS3
b) Buy an xbox360 then further down the line buy a PS3 as well.
Up to you!
If you are 12 or under = Xbox 360/Wii
and for haterz out there i got mine for £200
Its like me going into the Graphics card forum and asking if I should get an AMD GPU or a nVidia GPU...
Why dont you give us an idea of what you like or what you want to do with it...
In reply to your inane request - I like turtles
ps3ud0![]()
You can tell you havent been here long - what happens here is nothing to what used to occur with the GFX fanboys...How is it possibly like amd or nvidia? Neither graphics card company has games that only work with their hardware![]()
ps3ud0![]()
I get your point - just dont find it that relevant.
Asking an open ended question like that on either sub-forum and you will get the same type of posts from both camps - thats my point, not the fact you cant play PC games dependent on what GFX card youve got...
ps3ud0![]()
I have been told the ps3 online play is shocking. Its free for a reason surely?
I think youll find I put as much effort in as the OP did - didnt think it deserved anymoreTrue I understand your point now. You could have explained it better though![]()
