ipod touch 1st gen questions
6 May 2009
I bought a second hand ipod touch and am enjoying some of the great games like Cut the rope
Just a few of questions
Its running version 3.1.3, if I jailbreak it, would it be better?
When I power it on it takes about 20 seconds to come on, is this normal? (my classic comes on instantly)
When I try and copy an avi file to it, it wont add to it, do i need to messaround converting everything? Will jailbreaking it allow other file types to play?
They run the same OS, phone/3g functions aside it makes no odds
Tried it on my 2nd Gen iPod Touch and it didn't work. (OS 4.1)
"The app 'VLC' could not be installed on the iPod 'iPod touch' because it is not compatible with this iPod".
The 2nd Gen also doesn't get backgrounds with OS4, or multitasking, so the same OS but limitations. I guess 3rd Gen gets loads more then?
^ VLC probably needs hardware ARM7 Java acceleration or similar, so the OS version is irrelevant... just the relentless pace of smartphone development.
