Mercedes ML what to look for.
I really don't care if it sounds stupid, it's true.
Interestingly I have some similar real world experiences to you. I took off on an empty dual carriageway off a roundabout at full bore in my Z4M (same engine as yours) and couldn't believe it when an ML started to edge past me. I was using the gears properly too. I kept on the throttle as much as I dare and was safe and then had to back off with him having pulled perhaps a car length in front of me at three figure speeds.
Actually, this is horribly inaccurate. The diesel is an automatic yes? The torque here is at the flywheel, long before you shove it through the torque converter and then through a ropey 4wd system. The gearing will also kill it. His torque sits where, 1500rpm and blows off around 3.5k if he's lucky. The M3 has a much larger torque window so will use that far more to its advantage than the ML will. His box for instance will have made at least two changes while yours is still in 2nd (as an example)
Please explain that when evaluating cars performance potential on paper, which is what most seem to be doing here, looking at torque figures is "horribly inaccurate"?
Also, torque windows and peak torque are pretty irrelevant unless you also consider gearing ratio as well IMO.
Seeing as everyone seems to take internet reviews as fact, have a look at this one here. They seem to think it's rather "quick" too. First one I came across.
Mate, I can't believe you posted that. You're clearly talking nonsense etc.
Whilst I thank you for adding some support to my factual point, I'm sure the witch hunt from the keyboard know it alls will continue.
That might have been an ML63.
Oh ****, I forgot to mention something in my point. The ML in question in my post was an ML63 with Kleeman badges all over it so goodness knows what was running under the bonnet.
Which then suggests an ML63 is quicker than an E46 M3/Z4M. I'm saying that a 420 will stick with an M3 until higher speeds.
Hey guys, I was looking to upgrade from my 330Ci to an E46 M3 because I wanted better performance and a top of the range, high performance coupe from the same series, with a high bhp/ton, fast 0-60 and a more performance driven chassis and underlying technology seemed to fit the bill perfectly.
I'm now having second thoughts and based on this thread am now going to purchase an ML 420CDI as it is faster.
I mean, it has a higher bhp/ton rati......oh
Well, it is much lighte.....oh
Erm, the engine and transmission is geared for perform.....oh
Hmm. At least I'll have torque. Yes, torque will have to do.
It's simple.
An ML63 will kill an ML420 yet an ML63 can only just edge infront of a new M3. Ergo, an M3, new or probably old, driven properly, would trounce an ML420 :)
Actually, it does. Most recently, M9 slip road at Stirling services.
Then we are stuck in deadlock. You'll insist you are right because you have experience, therefore I'm never going to convince you.
Really, common sense? Why are you overlooking the torque figures then? Anyone with the smallest knowledge will recognise that torque figures are a more appropriate way of evaluating a cars acceleration capabilities on paper.
The ML 420CDI has bonkers torque, 516lb/ft iirc where as the M3 has c. 269lb/ft, so almost double. That's why it will keep up with the M3 until about 90 mph and then the M3's superior bhp will start to show effect beyond that. Seriously, get some basic knowledge.
I think its you who needs to go and get some 'basic knowledge'. What you need to focus on is the relationship between torque, revs and power and how this affects performance.
As a clue, you could try explaining how a Honda S2000 with less torque than a lawnmower once absolutely destroyed me when I was driving a 530d with TWICE the torque.
A Golf Diesel has more torque than Vettels championship winning Formula 1 car.
There are different ways to acheive power - you can go for low torque but a high revving engine. You can go for loads of torque through a low revving engine. etc etc. But at the end of the day it is the power figure that matters - torque allows us to understand more how it delivers that power. The ML420CDI will be easier to extract the performance out of, for example, the M3 needs to be driven hard to acheive it's maximum level of performance.
Again, you've got it wrong. I said it would keep up. It does. I've tried it several times.
The problem of course lies in what your definition of keep up is. Were you glued to his bumper the whole way without so much of an inch opening up? Or was he several car lengths ahead because in terms of acceleration a gap of several car lengths is an age.
This is why 'keeping up' is a meaningless barometer of performance and is hugely misleading when people try to claim that being able to 'keep up' says something about the cars performance.
Indeed, and again it appear here you are the master of assumption on the basis of ropey "facts".
How about you make me look daft by showing how my opinion is wrong, if thats what you beleive, rather than simply insulting me? The original M class was a poor car. It was made in America, for America and was poor as a result. I stopped short of saying the same about the newer shape and made a point of doing so!
Seriously, back off. You have no idea what you are talking about.
You seem to be a lone voice in this thread. Even BigT has described an ML encounter and that was an ML63! A massively faster car.
Nobody is saying it isnt quick - heck it does 0-60 in 6.5 seconds and thats not slow. People are saying it isnt on the same page as your M3.
Even your review provides context to the comments they are making:
Autocar said:
Despite tipping the scales at 2315kg, the ML420 shoots from zero to 62mph in 6.5sec.
In the context of enormous 2300kg 4x4's, 6.5 is a very respectable performance figure. It is this which makes them think it has awesome performance. They are not implying it's as quick as an M3.
This thread makes me LOL!!!
HummuH1 - but the ML63 can't be quicker than the 420 diesel as it has less TORKS!!!!!!!
Also sounds like you need some driving lessons if you can't beat the ML420 in your M3!!!
Also sounds like you need some driving lessons if you can beat the ML420 in your M3!!!
What would you know about cars Tom0, he has experience I bet you just google! :p
