6870/6850 volt mod ( trixx beta )
Works well on my XFX 6870 Black Edition
Clock 1100ghz Mem 1200ghz Volts 1200mv
Heaven at 1680x1050
@tommybhoy
I see where you are coming from, I guess I should have explained myself better :)
Those clocks are nice, but I like pushing things.
And as I'm hopefully getting water ( :rolleyes: ), would be nice to know how hard I can push without blowing something up. :)
Thanks in advance :)
Right, just messed around with it.
Got 950 core 1250 mem stable at 1.25 volts :)
If that's too much to chuck through it, who cares? I'm rather drunk right naow :rolleyes: :)
This is mighty ****** up version of Afterburner, messed up my idle voltage to stay at a constant level :(
It does what Afterburner doesn't without Unofficial Overclocking enabled but can't get my profiles properly and voltage control is definitely borked.
Why does GPU-Z show voltage drop when I use Afterburner then? I had to reboot to get my voltage back to normal.
The idle temps were higher too meaning that it must have messed with the voltage.
