Apparently your index finger is longer than your ring finger if you were exposed to high levels of testosterone in the womb, so they are hypothesising it's something to do with that. Mine is shorter btw![]()
My ring is bigger than my index finger. What does that mean?
You like cucumber ?
It means you're a big manly man oozing with testosterone but will probably die of prostate cancer*
*may be a slight exaggeration/lie
You like cucumber ?
You like cucumber ?
less test in a man makes you gay![]()
My index finger is longer. So I guess that means I don't have cancer/aids/gay/foreigner.
Mine tooNo, mine is noticeably shorter. I'm going to die![]()
