I sent Killswitch87 a 240GLT because I accidently mashed his car. Now it's gone into PSN land. Weird that as I've never had problems sending cars before.
clear cache in options, restart ps3. Some people say it works.
Would you recommend the Logitech Driving Force GT? Tempted to get a wheel, although it may mean plugging my PS3 into my Dell monitor due to the room layout.
I can't get gold on the Level 16 Gravel Rally either.
However I can "cheat" on the Loeb challenges - I've got a Logitech Driving Force GT which has a little jog dial to adjust TC settings and the like on the fly, and I can use it to set it to 50:50 torque distribution, which I found helps a lot.
A wheel is more fun anyway, so go on, you know you want to![]()
Wheels vs Pads:
- With the wheel you get extra realism
- You WILL be slower on the wheel to begin with, but you'll catch up/surpass your pad times eventually
- Certain things (NASCAR and Rally) will become easier, NASCAR because you can smooth your steering inputs, rally because with force feedback on you can feel the front wheels loose grip and "go light"
- Certain things (Drifting) will become almost impossible - If you put too much power on coming out of a bend, anything that would require loads of lock to correct you won't catch in time, however smaller wiggles as the car settles are easier to control
- Force feedback on these wheels almost counts as exercise
Onto the DFGT specifically (Warning this is the only wheel I've used in the last 5 years, so some of these critisisms may apply to other wheels):
- Designed for GT5, the jog dial (red wheel in the lower right of the wheel hub) can adjust brake balance, TC ABS and Torque Distribution (Where applicable) on the fly, SUCH a useful feature
- No proper flappy paddles - there are buttons on the back of the wheel that do the same job, but they don't feel crisp enough
- No seperate H pattern shifter or clutch pedal from the G25/27
- Only £80 at the highstreet store that sells stuff from a catalogue, much cheaper than the G25/27
- Are they making a new GT5 wheel? Twitter seems convinced they are....
- The wheel has 900 degrees of rotation lock to lock, thats insane, and you really feel it on courses like Eiger, on other games you can adjust this down to as low as 360 degrees (Dirt 2, F1 2010 Need for Speed etc), why not on the game it was designed for?
- Its also way to easy to hit the PS button, and way to hard to hit the start button - thats wrong way around
And finally.... for now, my BIGGEST ANNOYANCE
- The wheel calibrates itself LOUDLY by going full lock left then right every time you turn on the PS3, load a game, quit a game and turn off the PS3, this can be got round by pulling out the power cable when you start up and not plugging it in until you're in the game (Although it will still do that once). Its not subtle
I considered a G27, but went for this because in my opinion the G27 was twice as good of a wheel as this, despite being twice the price
Don't regret buying it at all mind![]()
- On a seperate note, wish there were more tracks catered for the drift mode, Ebisu anyone?
Im using this wheel as well, can you give me the specific setup you used(tcs/abs etc?)
TC = 0
4WD TORQUE 50:50 (from 30:70, should pull with the front end more now)
ABS = 1
Front Brakes = 5
Rear Brakes = 5 (I did put this up to 8 some of the time, but it doesn't make too much difference)
The rest is about being smooth, minimising wheelspin while they scrabble for grip, try to straighten the course where possible and feathering the throttle. Sideways isn't fast on this game, unlike Dirt
Also some of the driving line braking points are utter rubbish on the ice track, you can brake way later and sometimes not at all
Wheels vs Pads:
Anyone want:
- a Stratos Rally Car '77
- a Lambo Miura '69
Anyone got
- a Formula Gran Turismo
Looking to borrow or "buy" outright![]()
rp2000 you finished with my Gallardo yet?
If not does someone have one I could borrow for 30 minutes?
I got gold on that by going hard in with oversteer. I was trying to be too neat and tidy, but golded it after a few tries of flicking it hard in to the first left bend with a bit of oversteer corrected into the bend right. Try it out see if it helps.
and a gentle tap on the brakes and flick apparently does the trick. Bloody annoying!Anyone else got problems with trying to get a race lobby going just now?
