Project: Monster Energy Mod
15 Oct 2010
Hello
I am planning on building a computer case mod based on a theme of Monster Energy which is an energy drink which I absolutley love!
I am starting with A Raidmax Sagitta 2 case:
Here is the hardware I will be using:
  • Gigabyte GeForce GTX 460 OC 768MB GDDR5 PCI-Express Graphics Card
  • Asus M4A785T-M Motherboard
  • AMD Athlon II X4 Quad Core 630 2.80GHz
  • Corsair XMS3 4GB (2x2GB) DDR3 Memory
  • Corsair CX 500W ATX Power Supply
I am going to get some vynil stickers with logos, green fans, LED strips and cathodes as well as cutting the case itself. I will also try to get a custom fan grill done with a monster claw 'M' logo which can be seen on the can of the drink. The non-standard thing about the mod will be that I will also get all 4 different available types of Monster and take the cans and cut them in half and the side on which the logo is seen I will put on the side of the case and probably light them up somehow. Any ideas how to do that?
Comming soon - Sketches and pictures of making
sounds interesting, not to sure about the can idea though...
Are you going to be sponsored by Monster, if not why dont you contact them with your idea, you might at least get some of the caffeine and sugar mix.
Why not the can idea? Any other suggestions? I tried to contact them about it saying that I can also go to LAN parties and shows and help promote Monster and stuff but never got an answer. I will try again now.
PS I had a look at your Plan D and it looks great!
I think the cans will be flimsy and hard to work with i suppose you could fill them with expanding foam so they would keep there shape!!
Update 1
I have cut a can of Monster in half and actually you guys are right - the cans are very flimsy but thanks to Sayso's idea - I will use expanding foam to help the cans maintain their shape. The case is not the easiest case in the world to mod as the whole front is already really attractive and not much can be done here. The Window side is also pretty much out of action other than using vynil stickers like the following:
I will post sketches soon. Any suggestions for my project? What do you think so far?
Sounds brilliant, Monster is lush and the mod should go well with the design of the case, you should definitely try for some free drink too ;)
Hey guys this isin't really an update but I just made a 2D CAD design of the stickers I want to use as I now have access to a vynil cutter :D The only downside is that I will have to wit till they get lime green vynil :/ What would you do? Wait or spend more money? Keep in mind I only have a saturday job in a PC shop/rapair centre and don't get paid much :/
