q6600 bsod at 3.2ghz
4 Jun 2008
west yorkshire
my quad6600 runs fine at 333fsb, (3ghz) but when upping to 356fsb for 3.2ghz.
my temps drop lower,35-35-38-38 and all seems good,until i start a game then i get bsod.ive upped the volts from 1.25v to 1.50v but still crashes.should i try higher cpu voltage,or is 1.50v to high.
try 8 x 400 instead of 9 x 356 to get to 3.2, that will let you run your ram at 800mhz.
the board is more than capable of running 400 and higher fsb as that is what i run my q9550 at on mine :)
my ram voltage is set to auto in bios.
Most ddr2 will default to 1.8v on auto, though they can be rated up to 2.2v depending on manufacturer.
EDIT:Check the sticker on the side of the ram for the rated voltage.
set the ram voltage to 2.0v and 800 mhz and try 8 x 400 fsb
is this your ram ?
2.0v for this stuff
or is it this stuff ?
1.9v for this stuff
just set the ram to 2.5v in bios game crashed after arround 3 mins,
on ram box it says 2.0.~2.1v
i set the ram v to 2.0v and 8x400 ram at 800 and it booted,then on the first part of 3mark 06 it did bsod
