It's not a bug. That's the way it's supposed to be after a win7 install. It's caused by the 100meg hidden system partition windows 7 creates during a fresh install and is perfectly normal. HDTune reports the drive is 1024k aligned anyway and if it wasn't AS SSD would report your alignment in red and say it was bad. Forcing it to 1024k alignment by recreating the partitions manually should have no impact on performance as it's aligned correctly to begin with.
