i can only set it either 1.25 or 1.375 or 1.50v
im just trying 1.375v
9x356
ram at 736ghz on auto
ram at 2v
just got bsod
my fsb strap to north bridge is set to auto is this ok or should i set it either 200,266,333,400,
i think i have mine left on auto.
*edit - yup just checked my settings and its is on auto.
the only settings i have changed on mine are ai overclocking to manual, vcore to 1.2625 (1.24 after vdroop) and ram voltage to 2.3v, but that is with a q9550. a very lazy overclock i know but i reached what i wanted so easily
i had my q6600 on an abit ip35 pro
what bios are you running ? i'm on 1101
have you set ai overclocking to manual ?
you should be able to flash it to any bios you want to, you just need to download the bios from asus's site to a flash stick or cd then use asus ez flash in the tools menu in the bios.[/QUOT
ok ill try 1001 bios
ta.
