- 11 Aug 2010
- Cambridge
P5Q deluxe deffo.
Guys i removed the power cable out of the back and then plugged it back in. The time and date were still correct so surely this means that the battery is ok and not the problem?
I would still try a new battery, only going to cost you about £3. It really does sound like the battery is dead. What if any messages do you get on a cold boot?
And have you checked the CMOS reset button is sitting 100% in the correct place on the rear of the board? Worth checking.
For my Q6600 i had the Gigabyte DS3R, it was a bloody good board, got right up to 3.8GHz on it.
You should be able to get one right and cheap now too, i sold mine for £40
which is a lot. So if I set 1.4125v in bios I get the following:
