Next COD needs dedicated servers. p2p is starting to feel a little medieval.
Absolutely.
When I'm suffering from lag I bust out the ak47u with rapid fire and steady aim. Then just run around hip firing. Its awesome...try it out.
What does annoy me is I really like the 3/single shot guns but cant use them as I never quite know how they will reg. Next COD needs dedicated servers. p2p is starting to feel a little medieval.
)Am I right in thinking with Hardline Pro you used to be able to change the contents of the SAM turret, but now they have stopped that?
You can still change it atm, but after the next patch which should be with us in about a week it will stop it.
Are they just stopping that, or will they stop sentry gun change as well?
Sentry gun as well, you'll only be able to change care packages.
I normally switch the sam to something else, but I do feel a bit dirty and cheap doing it![]()
I know what you mean. I personally think you should be able to change the sentry gun, but not the SAM. That would make it a lot better
It's felt medieval to me since the 360 was launched.
I do the same I use rapid fire and grip on the AK with decent success. I've spent so long with the 74U now I feel like playing with another gun, an assault rifle. Rightly so the 74U is pretty poor at range I miss my ACR that was awesome at all distances![]()
Aug extended mags + sleight of hand beast!
Wouldn't it cost a astronomical ammount for dedicated servers ? Last night 500,000 were on black ops , I'd hate to pay that bill
Try the Galil, it has a bit more recoil than the ACR but works at range.
AK74 must be awful with rapid fire if they are more than 3 metres away, it's bad enough with the silencer.
I think the Commando is the closest you will get to the ACR on this.
