Wall Mountable TV. 32-40 inches £500
7 Sep 2008
this might sound strange but how do I know if a tv is wall mountable?
I'm looking for a new TV that I can hook up to my PC and play my XBOX on it.
looking to wall mount the TV so obviously one of those thin ones would be most slick.
budget is around the £500 mark - any suggestions? Also need suggestions for the bracket.
and how do I know if it will be wall mountable?
oh okay thanks
btw any of your got pictures of your tv wall mounted?
have any of you actually put the cables into the wall?
must look neat
oh okay thanks
must look neat
you have two options..
1) use trunking which sits on top of the wall and has the cables in it
2) chase out the wall.. much more expensive, but looks much nicer
option 2 - where you break the plaster put the wires inside and then plaster over?
lol sounds insane - but if you want to add wires later on it will be missions.
I think option 1 for now much less messier. or just run the cables nice n neatly
im thinking wall mounted tv with a nice shelf underneath it!
Buy these sorts of items on eBay. I picked up some nice swivel & tilt brackets (and some fixed) for a fraction of the price of the highstreet.
Chasing out the plaster isn't that hard. Obviously it will be messy, but if you are prepared then it won't take long at all. Get a nice brush faceplate for the cable exit, and if you want to pull more cables leave yourself a pull rope, or sink some trunking in the wall.
Here's my attempt at wallmounting a TV (link)
wow that looks amazing!!! I like the way you've used those sockets there.
so on ebay you got any links?
I'm thinking get the wall mountfirst
tv later
tv later
Not the one I bought, but here's an example of how cheap you can buy the fixed brackets for.
http://cgi.ebay.co.uk/LCD-PLASMA-TV..._Furniture&hash=item588b602dc7#ht_2882wt_1139
lol you're the geezer who made the house rotfl right?
nice one!!!! respect!!!
Yup. The picture above was from my existing house, haven't mounted the TV in the new one yet.
so will it matter which tv mount I get and tv?
looks like some of these mounts are - tv mount for samsung 96000 etc
Search for "universal TV mount". I've linked you to the one you want!?
