** Official World of Warcraft: Cataclysm Thread **
Grr, the install corrupted my installation. Had to delete the whole WoW folder and reinstall to get it to work. Now it's downloading anothe 9GB. :(
Playable copy in use all the time normally and one clean copy (all patches usually one before the actuall) stored on other drive "just in case ...."
For some reason I expected a new continent to explore :(
I would have liked a new continent too but you cant really take away anything from the new zones, all the ones I've been in so far are aesthetically pleasing whilst having really great quests.
A bit disappointed at the new 5 mans. Just hit 81 tonight; done TotT and BRC and it was just more of the same AoE faceroll!.
I'm hoping it's down to a well geared pug and that heroics require a bit of thought before pulling.
Currently in a queue of 3011 on Frostmane! Only logged out 2 hours ago too!
So glad I transferred off Frostmane! No queues on Bloodfeather tonight :)
just a quick question, my hunter still has the raptor he started with, is it worth getting a dif pet or are they pretty much all the same?
Just logged straight in...I guess my server just loves me or something?
Im really liking the new instances, but they are too easy :(
Guys, in Video Settings I use recommended settings but only ever get like 15-30fps ~(15 in crowded areas)
Is this right? I have a Dell M1750 laptop, i7, 4gb RAM, etc
How?
It will be much cheaper than that wouldn't it?
The Burning Crusade
The Wrath of the Lich King
Cataclysm
You will be able to get all 3 of these for way cheaper than £54
Edit:
Ive found them for £44,so not that much cheaper,im sure if you have a good search on goggle you will be able to get them cheaper
Does it cost £54 to upgrade via Wow ie: your account?
Yea, and that's with 20% percent off!
Ive just got to level 5 as a wogen,as i turned into a worgen i coudnt watch the scene,all i got was:
This Cinematic is not avaliable?
Then im changed as a worgen but i missed the scene ??
Any ideas why?
I bought the digital version download
Any ideas why?
The patcher installs certain data as far as you allow it. Maybe you're not 100% patched? It takes a while to apply even after the download has finished.
