sell it and buy a 6970![]()
[WU-TANG]GZA;17958632 said:6970 are supposed to be coming into the market at around £400 -
Following the OP - that's not really in budget. Try to be fair man....
If you have space and your motherboard supports xfire then x2 5850s will do better than a single 5870.
On the other hand the 5870s are really cheap at the moment (£190) so if you could sell your 5850 and buy one of those it would be an upgrade and then maybe xfire that later on- which is amazing performance.
That's my input anyway.
what psu power do you need for crossfire? I've got an Antec TruePower New Modular 650W
Here is what OCuk says about my card. i don't understand all that stuff sorryDepends on the 12v rail amperage.
I've got 3x 18A rails, and my machine at load pulls 420w from the plug.
50A+ on the 12V is needed.
IS it?
So all these wattage calculator are rubbish then?!
And it's running fine? Have you OCed your CPU?
found the voltages
INPUT
Voltage: 100 – 240VAC
Frequency Range: 47 Hz to 63 Hz
Current: TP-650: 9A @ 100VAC, 4.5A @ 240VAC
Efficiency: Min 82% at full load
OUTPUT
Voltage: +5V +3.3V +12V1 +12V2 +12V3 +12V4 -12V +5VSB
Max.Load:25A 25A 22A 22A 25A 25A 0.8A 3A
no need to buy another one then, I would be gutted If My crossfire made my PC crash94A, you're laughing mate![]()
