- 13 Dec 2006
- On the forest moon Endor
Oil level sensor or pressure sensor?!?!?
That engine only takes 3.4ltrs, so lobbing in 2ltrs randomly is a bit silly.
If I put oil in the car and the warning tells me it needs more wouldn't you check then put more in?
i had a oil level sensor flashing light after the snow... because the sensor was ripped off my sump by the ice![]()
Yeah that thought crossed my mind too - after I put the oil in
What where you thinking man lol. Hopefully it was the cold that made you crazy/
Car's spent the day down my local trusted independent who have drained the oil, flushed the system, replaced oil & filter and fixed a loose engine breather hose?
I've also just traded the little Seat in - cars served me well over the past two years but the mayo in the filler cap has me paranoid so I'll be picking up my new car next week
