- 8 Dec 2010
Hi peeps i kno there has been a few topic with a similar theme.
All it is i like to think i take my gaming quiet serious and atm i use a LG W2261vp which is ok for the moment but im looking to spend approx £200 + on a 24 inch monitor. HDMI is must aswell
Firstly is that the best size to go for? or is 26 + inch worth it bearing in mind it only xbox it will be used for. Picture Quality is a MUST !
Ive had my eyes on the following :
IIyama E2472hd - http://www.overclockers.co.uk/showproduct.php?prodid=MO-060-IY&groupid=17&catid=510&subcat=
M227WDP.
Samsung BX2450
but then i also like these.
Samsung P2450H - http://www.overclockers.co.uk/showproduct.php?prodid=MO-124-SA&groupid=17&catid=510&subcat=
BenQ Ew2420 - http://www.overclockers.co.uk/showproduct.php?prodid=MO-044-BQ&groupid=17&catid=510&subcat=
Internal sound is prefered but i do know some cheap 2.1 is probably prefered by most. But i use Steelseries 5xb majority of times so a monitor with a jack is a MUST
If anybody can put me in the right direction i would apprechiate it
M227WDP.
Samsung BX2450
