do u have a friend with a pc?
edit: u should be able to flash it in windows
Put the files to flash it on an empty USB drive, then boot using a Windows Vista or Win 7 32bit disk. When that boots you can choose Repair Computer to get to a command prompt to run the flash tool off the USB.
Yep, you can run the toolbox through the command prompt available on the Vista/7 repair disc (32-bit only!).
yesBut the SSD will be main boot drive. Can I still flash it while running windows and SSD as OS boot drive?
yes i did this. I have a Vertex 2 90GB.By the way. I have a Vertex 2 64GB.
The Flash tool from OCZ website is meant to be ran in a Windows exvironment.
Can I really boot into Windows (which is installed on the SSD) and flash the SSD which is at the same time running windows?
Final confirmation please before I install win7 on the SSD and then flash it.
Thanks
