- 31 Jan 2009
My Blue-Ray player won't work... when I put in a disk, it says "LOAd" then (sometimes "In It" (or 1n 1t) then "b d"
then it says PLAY and the numbers start to go round.... but nothing comes up on the Telly. I thought it might have been the HDMI cable so bought a new one... now I don't know if this was luck or what but seemed to fix it this one time.... then the next time it was the same problem again....
then I realised that when I turn off the blu-ray player and turned it back on the TV says "Blu-ray Disc starting up" and has the blu-ray symbol on the screne but then the screne goes black and the telly says "NO Signal" again.....
Does anyone know why it won't work? is it the telly or the Blu-ray player???
Thanks for your help xx
