The game is geared towards use of a gamepad though. Whazz in your official Xbox 360 controller for Windows and off you go.
AC1 is amazing on PC you can pick it up for a fiver in MorrisonsWorth playing on PC?
They've always appealed to me in terms of design, setting and style of play, but I always (probably wrongly) assumed they wouldn't be so hot on PC, being essentially console ports.
So, have I been unfair? Are they generally considered well made ports, or are they better played on console? Any glaring problems that should have been fixed with patching, but haven't?
Thanks for any feedback![]()
Good 50-75 hours gameplay time if you collect all the flags!! If you have an ATI card it supports DX10.1 as long as you do not patch it (there is a rendering error which makes certain textures transparent which should not be).
DRM is disc based only no online activation required.
AC2 also has the new Ubisoft DRM system which cloud saves the game for you but you need a constant internet connnection which is ok as long as Ubisoft servers are not under another DOS attack (which seems to happen at least once a month
) Biggest problem I found with AC2 is the boredom as its really an inferior clone of AC1 with much worse gfx & a longer but less interesting storyline. AC2 also needs a fan made mod to get the wireless 360 controller working easily as Ubisoft made a mistake they did not correct so wired controllers work fine but wireless do not until you copy the following into your AC2 folder.http://rapidshare.com/files/360926023/ACII_Wireless_360_Fix_by_Khemitude.rarThere wasn't even an option to use the X360 controller in AC2 when I last checked, let alone a pre-set layout. I recall AC1 could use the X360 controller, but the controls were botched or something because they weren't the same as on the 360 version itself, and no amount of customisation would make it work properly or the same.
Anyway, though, the games are good and I thoroughly recommend playing them. Can't wait for Brotherhood to come out on PC.
Great post - thanksAC1 is amazing on PC you can pick it up for a fiver in MorrisonsGood 50-75 hours gameplay time if you collect all the flags!! If you have an ATI card it supports DX10.1 as long as you do not patch it (there is a rendering error which makes certain textures transparent which should not be).
Gfx on PC are pretty good & it will run very well on any PC from the last 2-3 years easily unlike the console version the PC runs smoothly with no horrific screen tearing & it even gets 4 extra mission types so its an enhanced version of the console game. But like so many recent games the gameplay is similar as in do this do that then repeat a lot (no better or worse than any other game though) but I personally loved it as the cities are absolutely massive to explore the amount of detail in them considering their size & how its all a single load for each city is very strong technically & it has quite an amazing atmosphere in placesDRM is disc based only no online activation required.
AC2 I did not like as much. The gfx are DX9 only & look pretty poor in places like PS2 levelAC2 also has the new Ubisoft DRM system which cloud saves the game for you but you need a constant internet connnection which is ok as long as Ubisoft servers are not under another DOS attack (which seems to happen at least once a month
Download this it fixes the 360 wireless controller problem in AC2!
I passed on AC2 due to the DRM, which is a shame because I liked the first one despite its faults. Still if Ubisoft don't want my money, that's their problem. Plenty more games to play that don't use such an obnoxious system.
Your missing out on a really good game for no good reason unless you still have dial up internet' It causes zero problems for me as it auto logs in and loads the game straight away just like any other game.
