just about to try oxygen for the first time, finding the hd roms a little laggy, just need to see if i can live with dialer one, failing that it will be back to leedroid
i might try oxygen, can someone remind me its been a while. im rooted.
chuck the file on the sd card, then wipe, then update?
way i did it this time was full wipe, partition the sd card in recovery, removed the sd card place in card reader copy rom across put sd card back in phone boot to recovery and flash, if your just wiping you can do it the way you have stated
Anyone flashed Oxygen v1.0.3 yet? New market included along with plenty of tweaks to the browser and reverting to the standard gallery app vs Gallery 3D.
What do you remove the card and put it into a card reader for?
Just enable USB-MS mode in recovery (it's in AmonRA, not sure if it's in Clockwork) and it will mount your SDCard whilst in recovery, so it appears as a removable drive in Windows.
Then just copy ROM over and then disable USB-MS mode again.
Yeah and as usual, everything running fine!
