Permabanned
- 9 Sep 2010
Oh, it will also be worth checking to see if there are any drivers updates for your motherboards chipsets!
clarity of words is needed here.
5850 performs better than the 5830.
in terms of speeds the 5830 has a faster core clock.
but yes as a possible answer to the problem this is no uncommon. google may have a answer.
Of cource it is, it can process more frames in any second than a 5830 = faster.
Who said
And laughed at themselves as they did, silly!
well if we are going in to this really the 5830 can do more frames per second as its faster core clock makes it render faster.
But the 5850 can process more pixels per clock then the 5830. this is how it performs better.
in terms of faster you may have a point there but it can lead to confusing situations when the device your measuring on speeds had a chip that runs at a speed.
back on topic i know this may sound mad but put the 5830 in the top slot. if there is any down clocking then this will force the 5850 to OC to the 5830 speeds.
but looking on google many people confirm that this is a fault and there appears to be no work around.
You're completely ignoring the fact that when people refer to a card being 'faster' they are talking about the overall graphics performance. There's no lack of clarity from anyone else here - the 'faster' card is the 5850.
This kind of thing is a common mistake made by people that don't really know their way around computer hardware - assuming the biggest number of mhz/ghz is always best.
hey i know my stuf. this is the first time i have ever heard people say a card is faster than another card. i am very used to a card Performing better than another one. i accept that this is a difference with this forum.
Thats right it's my undertsanding is the faster card will be brought down to speed with the slower card in your case it's the 5830.
try putting the 5830 in the main slot and 5850 in second slot..
crossfire doesn't under clock the higher clocked card.
