(The reason I use a Radeon now is because the AMD chipset mobo blue screens with an NVidia card ...)
What are some examples of human error and PEBKAC when it comes to video card drivers?
I'm struggling to find any to be honest.
Originally Posted by FrenchTart
So your current problems are caused by the Radeon card, even though you've said your Nvidia card BSOD'd previously? Could not the common element here be any other part of your system?
Originally Posted by straxusii
You couldnt make this stuff up if you tried![]()
LOL
So you get loads of problems with Radeon cards and Nvidia's give you a blue screen, so its the catalyst drivers fault. Atleast your system actually lets you getting the radeon drivers installed and working lol!There is no such thing as a WORKING Radeon driver.
Never had a problem here... which doesn't help you much![]()
I just use the ATI uninstaller, restart and install new.
It is common knowledge Catalyst uninstaller does not uninstall correctly, and the files it leaves behind cause issues. That is why Driver Sweeper exists ...
Makes it kind of hard to test software in vsync mode.
It may be something simple like a bios setting, or a motherboard/gfx BIOS update you need.Common sense would suggest that AMD chipset mobo + NV GPU are not happy.
As previously I had problems with NV chipset + AMD GPU ...
Anyway in future it is Intel chipsets + NVidia gpus and then maybe I can get some work done.
Same here. The main problem on these forums is that people overclock their cards and use beta drivers. Stick to official driver release and don't fiddle and you will have few to no problems. To be fair, I have never had any problems with Nvidia drivers - just don't get me started on the 7900GTX though![]()
