what's the onboard video like? play 1080p?
Its a Radeon 4200 with 128Mb fixed ram. It SHOULD do x264 video at 1080.
config:
NAME STATE READ WRITE CKSUM
tank ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
c4t0d0 ONLINE 0 0 0
c4t1d0 ONLINE 0 0 0
errors: No known data errors
root@openindiana:/tank/testdir# dd if=/dev/zero of=zerofile.000 bs=10M count=3200
3200+0 records in
3200+0 records out
[B]33554432000 bytes (34 GB) copied, 345.481 s, 97.1 MB/s[/B]
root@openindiana:/tank/testdir# dd if=zerofile.000 of=/dev/zero bs=10M
3200+0 records in
3200+0 records out
[B]33554432000 bytes (34 GB) copied, 171.858 s, 195 MB/s[/B]
Ive got Server 2008 R2 running nicely on mine
stuck a blu ray drive in it and encoding on the fly is fine.
Ive got 4gb ram in mine the dual core 1.3 seems to cope ok with the load sat at about 97% load converting to MKV cpu has hit max 42 degrees so far and its been going about 2 hours.
no IDE they have 1 SATA for Optical Drive / extra hard disk.
One Mini SAS to 4x SATA hardwired to the hard drive backplane
One internal USB Port for OS that can be installed to flash media
One E-sata on the back
Adaptec 3405
Just received email confirmation of my cashback from HP![]()
Hey mate, on the form for the Company Name and Address, how did you fill it out? (Presuming you purchased it as an individual that is...)
HMm I put N/A in company name field. They have my name above it so shouldn't be a problem right?
I guess if it is and they want a name they can always email me for one.
As per the Tech Heads VMWare site I'm I've ordered mine for a vSphere box
Paid £259 for mine then take £100 cashback off.
Includes 4GB RAM, DVD and USB for ESX embedded
So whats better WHS v1 or the WHS Vail Beta at the moment it still has drive extender.
So is drive extender like a software raid ? Whats it sort of equivilant to ? Raid 5 ?
And WHS v1 used to write everything to the system drive first and then copy it to the pool. I dont think it does that now though. Is that right ?
