hey just a shout out to everyone who hasn't updated there drivers yet.
you may want to take this under consideration when you choose to or not.
i updated to 10.12, the over drive is buggy as when you oc, the min oc value is the actual oc value, may not matter.
when i overclocked my saphire HD 5870, games crashed my pc with solid vertical lines. this occured even when overdrive had default clocks but different fan speed!
so i set out to get back to 10.10. this i found was almost virtually impossible!
short from, swapping cards with a hd 4870 and 5870 (it failed to install even on the 4870
), using drive sweeper and installing the software over 20 times and going a-wall in regedit, i succeeded. a lot of unnessary stress for almost 0 improvement and a peak at the UI, just isn't worth it. best part was that i could install 10.12 again but not 10.10! Confused!
