- 22 Mar 2009
I had 980x before but I now in favour of the 920 than the 980x because of overkill better.
I just installed a new 980X over the w/e, actually a bundle from overclockers:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-031-OB&groupid=43&catid=339&subcat=1801
It will be used for evolutionary algorithm simulations, alongside cuda-based sims, so I actually do need it. Compared to my previous Q6600 @ 3.6Ghz it flies along.
I'm still installing software on it, but a quick SuperPi 1M went from 30 seconds to less than 10. I know it's far from conclusive, but it's definitely indicative
Can't wait to get number-crunching on this bad boy.
Oh, and kudos to OC for the bundle. Nice to get a pre-overclocked, pre-tested system where everything just works out of the box.
just thought i would let that sit in the back of your mind. lolBut ye you must be the only person i have seen that really needs the 980.
I would like one too. Just comtemplating getting the 980x or the 970
you can get a 980x for £599 mate.....
no unlocked multiplier on 970![]()
(j/k)Cheap ones they are then. Not engineering samples are they/used? if its got "rjkoneill was here" written on the back, then be afraid...very(j/k)
My 980x was just under £500 in an auction - I missed one (because they mis-spelt the title in several places and so badly only one person spotted it - I found it when looking through the sellers completed auctions) that went for £99. I run a dozen or more VM's on it - but theres usually only 2-3 running - with the rest available for gaming and other things. Was sold as new - but you never know whos telling porkies - the serial no was about 4 months old.
