- 28 Oct 2010
- Colchester
i've been after a h70 for a while now and i think its time to order one now
. i have the k62 case, at the back of the k62 case is two rubber holes, i was wondering is there a way i can take the tubes off the h70 and thread them through the holes and out then put them back on with out messing the h70 up?. if you can't then no problem.
the reason i want to do is, the temps inside are 20'c inside my case, out side of the case is about 15'c, as my pc is in the back study room its so much colder, so that would mean the rad will be more cooler. i will also be adding two viper fans to it as well.
any help would be gr8.
Thank you & happpy xmas.
. i have the k62 case, at the back of the k62 case is two rubber holes, i was wondering is there a way i can take the tubes off the h70 and thread them through the holes and out then put them back on with out messing the h70 up?. if you can't then no problem.the reason i want to do is, the temps inside are 20'c inside my case, out side of the case is about 15'c, as my pc is in the back study room its so much colder, so that would mean the rad will be more cooler. i will also be adding two viper fans to it as well.
