Yeah, concentrate was of course cheaper, but I can't be arsed with that.[TW]Fox;18075670 said:5 litres of concentrate for £3.85![]()
Open bottle, put funnel in cap, pour liquid, close cap. Job done.
Mark I think it's time to stop with the booze and have a nap.
Howard...go ask your car?
Anybody who puts pure water into their car anywhere is an arse, be it radiator or washer fluid![]()
IT wonm't tell meI just wondered if anyone with a mk3 mondeo or ST220 knew for sure
To defrost the pipes , I'd try boiling water all over the tank and pump and the jets, if that fails just chuck it in a garage and put a fan heater under it for a couple of hours much easier than taking it apart..
For screen wash I'm currently using 95% methanol 5% water, its a waste product from my Biodiesel production so free and good down to about -90 degrees![]()
It's not an exterior issue, my hoses are patted down with a luke warm sponge when defrosting the car everyday. Generally run the car for 30-50 minute motorway trips so that should be plenty of time.
[TW]Fox;18075712 said:Open bottle. Put funnel in cap. Pour in half the liquid. Fill rest with water from hose. Close cap. Job done![]()
Just mix it up in a jug, easy peasy. Asda stuff must have changed since last time I bought it though, I filled up with roughly 80% mix and now it's frozen again, that's never happened before.
how do you know what mixture you have though?
half the bottle of screenwash + rest water may be like a 10% mix in some cars.
[TW]Fox;18081083 said:Read the bottle, duh.
