Software to mount an iso file as a virtual drive in windows?
31 Jul 2009
Hi all, I have a 5.2GB iso file I need to install but have no Dual layer DVD drives. In windows xp mode using VPC, it is possible to mount an iso file as a virtual CD drive. Is there any (preferrably free) software that lets you do this in windows 7 (64bit)? Thanks.
daemon tools lite is free and also easy to use.
install it
then go to the icon near clock and right click on it and select virtual device (drive letter)
then select mount image
then browse to the iso file and click select.
then the iso will load
or use google for directions
sometimes i cannot get daemon to install the silly stpd driver, and then i use virtual clonedrive which is probably easier to use
Virtual Clonedrive is the best.
Daemon tools don't even make their own driver for their software, they rely on a 3rd party
