- 3 Oct 2006
sounds great gars, loving the stuff about the shop, i'll make sure it's the first building that goes up ones the land is cleared and the floor is half stoned.
Sounds great garsands. I haven't been on today as I've been visiting relatives, but I'll be on in a bit and I'll try and sort some prices out
Do you want me to modify and post up a price list? Also, do you want every item on the list for sale? Any restrictions? Do we need a physical hub to buy/sell stuff too? I don't know how it works in-game.
Glad to hear that the rollbacks are hopefully fixed too!
Garsands do you still intend to give every player a 'vault' that only they can teleport into?
Easiest thing to do there is to set it up in a spreadsheet, then you can just set up the formulae for each item to make sure you get it all right. It'll even update when you need to tweak the raw material prices.Like I said the hard part is making sure it does not cost cheaper to buy a item ready made then it does to make it yourself.
It's not a easy job.
bah humbug, server is full
Im becomming addicted to this game![]()
Can we get more slots please Garsands?
Yes I do was just saying about it on the server it's my next job to do, but I can't do it till the server is empty as I need to clear a huge amount of space underground at the base of the world out of the way.
I will be doing this using a command but it may crash the server in doing so & I can't risk that while players are on.
If I can't find a time on Monday when there's not meny on I will do a world save then warn the players that the server may crash, if it does I just have to reload the world save.
There really ain't no need for more slots in my opinion. Give it a week and it will die down a lot.
I am going to have to anyway looking at the xmas new year opening hours for such changes.
The problem you are going to have is all you are going to see from the outside is a 198 x 198 bedrock cude & if it was under the spawn it would also start just below gound level & go all the way down to the bedrock base of the world.
You could have steps going down to each vault but as there are no doors the steps would lead no where.
i just figured as people weren't going to be digging under spawn it would make it the perfect place for the vaults![]()
