Spec me a AMD bundel
ok ddr2 it is bear in mind that this won't be very upgradeable and is dated
mobo http://www.overclockers.co.uk/showproduct.php?prodid=MB-299-GI&groupid=701&catid=1903&subcat=1482 £50
cpu
http://www.overclockers.co.uk/showproduct.php?prodid=CP-265-AM&groupid=701&catid=6&subcat=1328 £68
total £118
anymore than this and you won't really see any benifit so there is no piont in spending money on a flash cpu
cant somebody confirm the parts are compatible as i this this is for me
they are compatible :p why would i misslead anyone?
the mobo is ddr2 am2+/am3
and the cpu can be used with either am2+ or am3 as i have a phenom and wnt from an am2+ to am3 mobo myself and you have ddr2 ram which is compatible
you did ask "dose themobo above that i spec'd support 125w cpus? " there was no reply
I would go for that CPU because nothing he does now requires beefy single core performance, but in a couple of years time the extra cores will be handy.
